Band Clamps vs V band
Professional Hoon
Me and my dad will be stating on a new 3" exhaust this week. So the question is, What would be better to join the exhaust insted of bolt flanges. im thinking about v-band but also band clamps but not sure how band clamps will hold in the long run.
anyone with any experience with 1 or the other?
I found it realy difficult to assemble a v clamp at the dump pipe so stick to the flange there .
for the rest of the exhaust Vclamps are kind of handy as they allow you to rotate the pipe a bit so they are a bit more forgiving .
the ebay ones wont seal any good ..as they are you just need to make gasket for them..
the other thing you can do is machine the 2 faces so they have a 45 deg seat so that the 2 flat faces don't quite touch this will make an ok metal to metal seal..i can perhaps send you a drawing if this doens't make sense ..
Professional Hoon
Dump pipe as in down pipe from the turbo? if so im keeping that flange there. using a reducer/enlarger 2.5" - 3" there.
as much as we wanted to get the 3 - 3.5" downpipe made, we've decided to keep this exhaust simple just with the limitations we've got at home for the time being.
I'm not planning on using Ebay parts for this, as yes they tend give more headaches.
i'll be getting parts from a local truck / exhaust store in laverton north. i was thinking of using band clamps it looks alot easer but im not to sure how they will be in the seal.
so your to rich for ebay hey Pauly ?
if your not sure they are going to seal why pay the extra money from the truck guy..
ya old man will get them to seal with a gasket or my maching 45 seats in them..
the truck guy should be able to give you slip fit clamp on flex joints they will cost you a few more bucks but make the job pretty easy
yeh where ever ever i have cheap ones and they seem fine ..
but these look to be a help![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
http://cgi.ebay.com/ebaymotors/Comet...#ht_3672wt_948
Professional Hoon
ahhh yeah, and it's still cheaper then $70 a piece from a local place.
Where would you buy crush rings from for the x over pipe and down pipe local? i've caled local exhaust shops and they dont have any and porsche sell them for 80 a piece. The only thing i can think of is pauer turning or LR where they're 20 each.
they are actully very reusable you as long as you don't butcher them .
there are plenty of US shops that will put them in the post for you and youl have them in 3 to 10 days you just have to remind them that a prepaid box is 14$
so lyndsey
pelican
EBS there is thred on here full of them somewhere
this is the best guy i found for new stuff localy so far but i have only got merc stuff as yet but he has been very helpful and his prices are good
http://www.discounteuropeanautospare...ced24e1a543530
so lyndsey
pelican
I am using band clamps bought from JEGS since I use them to swap a straight pipe and cat. When it comes time to pass emissions here in NJ, I install a universal cat with the band clamps making the transitions simple. If your worried about exhaust leak, just tape some exhaust repair tape around the seam for extra measure.
i came unstuck once with ebay bends some 2" ones i got were 1.2 wall thickness wich was difficult to weld but i got a full 4" system with 2 mufflers for about 350$ most of it is ebay some of scrap yard but there is nothing wrong with it
If you're using v-bands I sugget offsetting the flange on each pipe section by about 5mm to provide an overlap so that one pipe section slides into the other flange. (not very well described)
Helps to keep a nice tight seal.
