951S PMR Spec Race Camshaft - Que?
Hi RL. This item was on the list of receipts ~$1000 if memory serve. $650-$1000, for my 89 951.
Pros? Cons? I can't find anything about it online (con).
Car also has 3'' Fabspeed exhaust, Vitesse Stage 2 or Autothority Stage 2 chips, wirefire headgasket, Lindsey Boost Enhancer, and some other things I am still discovering.
Links/Data welcome!
[Car is now up to date on Timing, Balance, Rollers, etc].
*edit. Got the specs. PMR did not have the info. Sent me to Engine Builder Supply, who was very helpful.
The specs should be as follows:
Duration: 256 degrees
Lift: .470"
Lobe center: Stock
Links/Data welcome!
Lift: .470"
Lobe center: Stock
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
So Reno, if someone searches and can't find anything, what do they do?
I'll bet what they dont want is for someone to say search and offer absolutely zero help/contribution.
Just sayin'
RL search now sucks donkey wong. It has since the new owners took it over. It's AWFUL!
To the op. Sorry. I don't have any info for ya. Does your paper work have the cam specs? That might help one of the guys ID it for you.
-BB
Updated first post.
Lift: .470"
Lobe center: Stock
Exhaust is full 3'' Fabspeed with high flow cat (also have straight pipe I could put on). Exhaust manifold is stock I believe? Unless that is part of a full exhaust, I would have to look, I do not know what stock is supposed to look like.
Lift: .470"
Lobe center: Stock
