Thats a very nice car for sure.. Can I buy the old engine when you're done with the new one.. I'll even drive to Tallin and let you guys install it as well... You sure seem to know how to extract some impressive numbers from the 951...
Thats alot of Torque! what compression ratio is this?
Dyno chart please?
9,1:1 I ll upload chart later.
Originally Posted by ModdedEverything951S
Are stock 968 pistons the best choice to use here?
New pistons + job with engine block would add a quite big amount of money to budget. 3.0 8v engine was also running with original pistons, never had problems with that.
Originally Posted by DLS
Tell me more about the VEMS programmable ECU
is it plug and play now with the original harness?
No, it is not plug and play. I would never use used harness for VEMS. It has self made harness.
Originally Posted by V2Rocket_aka944
why does it have different wheels in different pictures
On second picture rear wheels are 15" with MT Drag.
Originally Posted by Dougs951
Tell us more about the m5 half shafts.
Rear axel side are custom made flanges and transmission side are used Audi flanges.
If anyone should be interested in these flanges let me know.
