LS1 kit suppliers, list of avaibale suppliers
#47
2ps bell housing
I bled the clutch on my new build yesterday and was able to see the clutch release with the bottom of the bell housing removed and was also able to verify I had no leaks. With the remote bleeder it took about 15 minutes total to get it done. If you are looking for a remote bleeder Tick Performance makes a good one for $45.00 if you don't want to piece one together yourself.
#48
Can anyone tell me what throwout bearing they are using with the Quicktime Bellhousing? It seems to have a ball for a conventional fork, but no place to mount a slave cylinder. Can I bolt in a C5 Hydraulic slave inside the bellhousing?
#51
#52
my RH sump is leaking badly, bad weld in the AN nut to tube weld, on rear... also 1 of my headers didnt fit, but they sent me a new one for free, so good customer service, but perhaps not the best quality control, they in turn probably just buy this from someone else though.
#55
#57
Rainman
for the record, people wondering about v8 swaps...
http://paceperformance.com/i-5135065...ual-trans.html
about bellhousings, does it have to be a C5-specific piece or can you use the generic SBC bellhousing (from every 3rd-gen f-body at the junkyard), if you don't mind a one-piece unit?
#59
Rennlist Junkie Forever
Mine never leaked. But I did buy another because somone lowered my car down on the lift and dented the bottom of it. And while it's easily repairable, I needed one ASAP so I bought another from Renegade Hybrids. That's the one I installed on my LS6. And it too doesn't leak at all.
TonyG
#60
Is that a RH oil pan? I ask because both of mine don't look like that. They don't have the semi-circle cut out around the oil lines.
TonyG
