Anyone know how this Oil sending wire is routed
I know it goes over the water pump, after there is a mounting point see 2nd picture but there are two plastic clips that snap into an l shaped bracket One is on the corner of the head in the front of the car ... were does the other one go?![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
Also,( at the top of the 1st picture ) is that sensor on the (?ORV) supposed to be, that close to the power steering line? I can barley get the contacts off without removing the line clamps for the PS line
TIA
Ed
TIA
Ed
IIRC it belongs between the PS pump and Balance shaft cover, then down to the side of the oil pan (I assume you mean the yellow wire) as it is the wire for the oil level sender on the side of late oil pans...
Also
TIA
Ed
Yes you are correct, I was looking for the exact routing because there are clips that snap into the body somewhere ... I was hoping someone with a later car could maybe take a picture as to how it is run
Also
TIA
Ed
Also
TIA
Ed
OH and the sensor you are asking about is the oil pressure sender... the other wire you are asking for routing on is the oil level sender wire!
Thanks John No rush ... I got plenty else to do
regards
Ed
regards
Ed
Ed, took some pics today, sent em to you, let me know if they are what you needed to see or if you want the high res versions...
I downsized them to aprox 1024x768...
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Well John was kind enough to take a picture and find where the other mounting point is !!! For the life of me, I couldn't remember where the little bugger was
Thanks John very much !!
I thought I would post it with a circle on it for anyone else that may need it in the future
Best regards
Ed
Its all good, one day after my turbo is back in play the N/A will get an overhaul similar to the turbos... the turbo just wanted to be done first...
