Lindsey afm chips and k27/8 turbo. First impressions
Old 10-20-2010, 12:03 PM
  #31
toddk911
Drive-by provocation guy
toddk911's Avatar
Originally Posted by TurboTommy
Those of you running this super 75 turbo; it's a ridiculus oversized compressor for a 2.5L.
Just to put it in perspective: it's bigger than the turbo that Duke is using on his 16 valve high flowing engine which is presented on one of the threads here.
Laws of physics: the bigger the compressor the more exhaust pressure is needed to power the thing, given a certain size turbine wheel/ housing size combo.
As for the Lindsey #8 vs the "Porsche" #8; are you looking on the inside, where the cross-sectional area meets the turbine blades?
If it's a bolt-up turbo, wouldn't they both be kkk? It should be the same size. The original #8 had a 55mm wheel at the outlet. What size is yours?
I see 1 bar in 4th at about 3,800 and from 1 bar to 20psi in about another 400 rpm. I also see 17-18psi by the top of 1st gear.
Old 10-20-2010, 12:19 PM
  #32
azbanks
Freedom Enthusiast
azbanks's Avatar
Originally Posted by MooreBoost
it doesnt rust!
What is "rust"???
and what is "rain"???
I live in Phoenix.
Quick Reply: Lindsey afm chips and k27/8 turbo. First impressions
