Airbag light, seatbelt light, "!" light, all on at the same time...
Wax On, Wax Off
so I just went and reviewed the wiring diagrams, Josh, do you think that possibly a short in the seatbelt light could cause that?
per clark's garage:
I've traced the wiring diagram, the wire that goes from the airbag control module that operates the seatbelt light migrates thru the fuse box into Relay G16 (gong relay). then it goes up to the gauge cluster. I'm thinking the next place I'm gonna check (tomorrow) is the connections at that relay, because we did take out the fusebox, I'm wondering if something didn't get pinched or whatnot when we did that.
per clark's garage:
Originally Posted by clark's garage
Failure Warning Lamp-Short circuit
Central warning lamp and belt symbol still light up after failure of the airbag sign.
Remove and check control lamp and replace if necessary.
Check wiring harness for damage and replace control unit if necessary.
Small Business Partner
Possible I suppose.
Re: pinched wiring - also a possibility, though I think it is just more to deal with moving around old wiring...
Wax On, Wax Off
Warning lights are out!
I was having a bitch of a time finding anything wrong, so I jammed on down to the local Porsche shop, spoke with the shop foreman who's been working on 944's since the day they were released. he told me there was probably nothing wrong, and I had probably not been effective with my reset procedure. I showed him Clark's garage instructions, he said they were accurate, but instead of attaching the alligator clip to the door latch, attach it directly to the negative battery lead. Then he suggested to use a stop watch to make sure I got 5 seconds surgically accurate between actions with the button. so I did those, and the light is out!
Happiness is zero warning lights on the dash.
Take a look at the airbag blink code procedure on Clark's Garage as well. Tip: Record the blinks as a video on your cell phone, much easier to count them when you can play it back as often as you want.
In my case in turned out to be a fault in the slip ring/clockspring.
Clark's Garage has procedures for reading codes, the code table and resetting the light
http://www.clarks-garage.com/
Click on Garage Shop Manual from the left side navigation pane
Scroll down to Body, the Airbag procedures are the first two in that section
Bookmark Clark's Garage, it's a fabulous resource!
Best of luck with your issue.
Like what the porsche dealer said, you have to be accurate with the timing of the switch. I rigged up a test rig and left it in my glove box (on a long wire). I attached the alligator clip to a bare metal hanger behind the glove box and that works fine. Mine seems to go off every month or so and not due to the same issue. I like to not have lights on when i'm driving, esp at night.
