Best Way to Make Power / Power Limits of 951 Engine.
#46
#48
his email was about his honda 2.5L not his doom engine... and the all the info about the doom engine on this board is from people way down low on the totem pole and is circumstantial... i figured why not email the main guy and ask him so we can stop going around in circles here...
#49
It was the most powerful engine Grand Prix racing has ever seen - including the glorious pre-war era with the mighty V12- and V16 units of Mercedes-Benz and Auto Union.The 1.5-litre engine Bavarian Motor Works from Munich entered Formula One atthe South African Grand Prix in 1983 in a Brabham BT50 chassis reached a top level of nearly 1.500 bhp in its qualifying version. In spite of a politically difficult first season with a non-qualification in Detroit as its climax the Paul Rosche designed 4-cylinder-engine became so very fast a competitive one, that Nelson Piquet was able to win the Canadian Grand Prix one week later.
http://www.research-racing.de/bmwturbo.htm
May be a read of interest. Know money, engineering, and money will make your HP dreams come true.
ps The dyno's are the reason I usually assume/hear but what I'd really like to know is if there is some difference in units that explains it. I recently saw a car for sale on here that had comparatively very little done to it and quoted figures 100hp higher than I would expect to see on a similar car here. I have no doubt that the figures quotes were real because even if you blag elsewhere you'd be a fool to post false figures on an add in an open forum.
The main reason I'm asking is, there are so many modified 944turbos in the US that it would make an amazing resource for data but at the moment the results are so varied that the data makes no sense.
A useful bit of information (for example) would be what is the maximum output possible on a 944 for each injector size? Surely this could be worked out mathematically but what people say you need and what people say they have achieved are quite different.
#50
Bannana Shine
It's mostly because people generally test power on wheel dynos instead of engine dynos, and wheel dynos are voodoo.
#51
Small Business Partner
#52
Bannana Shine
I'm saying that the machines are voodoo because they produce completely inconsistent results, even on the same dyno day to day. Sure they're useful for testing percentage gains/reductions in power for a particular mod on a particular car that you can bolt on/unbolt within a matter of hours, but for absolute numbers, they're useless.
#53
#54
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#55
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
#56
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
We are getting 1600 hp from our 2.5 liter Toyota 4 cly. If you
run alky and a 944 head with the intake porting of a 968 you can make as
much or more than that. I have made 900 hp on gas with this motor in road
race trim. I do not know how much more the bottom end is good for as I have
not leaned on it more than 900. Alky and high compression and boost with the
right cam timing is all it takes. We are making 2500 to 3000 with the 4 cly
in my pro mod car. (fastest 4 cly in the world) If you tell me what you are
going to use the engine for I can be more specific.
#57
Bannana Shine
So what we need is an international dyno day to get all the modified cars on the same dyno on the same day. I vote wherever this guy with the 900hp 944 on standard internals lives. That way we'd all leave with a smile I'd love a 1000hp graph for my car
it would fit right in with the you tube movie titles "watch as this 800hp 1.3i ford with a K&N filter races the 700hp 1.0 polo"![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#58
If you are talking comparing results between different makes/models of dyno's I would agree - especially on those that require much more user input. The reason I like the inertial dyno unit though as it is simple and consistent. For tuning though you are probably better off with an eddy current dyno.
#59
I realize that dyno's, like any other instrument, can have errors. One of the biggest things, that i rarely see posted on dyno sheets is correction factors. Here in Denver that really matters as typical summer factors are 1.25 to 1.30. If that is applied applied to a turbo car it is somewhat misleading.
The NHRA applies half correction to turbo cars which is probably more realistic. However, when I get dyno sheets in Denver, I like to see uncorrected numbers.
If I take the car to a dragstrip, the ET/MPH gives me uncorrected time which should match with the dyno.
Case in point. The Dyno Dynamics vodoo machine "measured" 255rwhp uncorrected for my car. Using a 15% loss, that should be about 294crank hp in Denver. At the dragstip the car posted 103.89mph. On the dragstrip scale with all the crap in the car (fuel, me, spare tire, etc) the car weighed 3290lbs (it needs a diet).
Using the generally accepted formula >>> hp= (trapspeed/234)^3 * weight <<< it shows my car should require 292crank hp to reach that mph.
I have just shown you an instance where a dyno shows the same number as real life within a small window of error. You shouldn't believe all dyno lie.
-Dana
-Dana
