Header wrap or Ceramic coatings
Rainman
is my thinking correct in that it would be best to coat both inside and outside of the exhaust system? my thinking is that the coating on the outside, probably the shiny stuff, would reflect outside heat and the coating on the inside would keep heat energy contained within the pipes and would mean more heat energy to spin the turbo...or is that overkill?
I talke w/ Swain this Am, I don't think theat they generally coat the inside for turbo applications.
I aked about coating and wapping. Their thought is that might lead to premature failure of the coating due to the fact that the would be more heat retained the coating alone. And it is the expansion of the metal, due to excess heat, that will crack the ceramic.
I am thinking of going w/ the white lightning then spraying a VHT paint on top.
Steve
Steve
FWIW, Swain is local to me and last year I met the owner and got a tour of the facility. The owners are incredibly knowledgeable, have a long racing history, are thermal engineers not just coaters, and will do things the right way. It is quite an operation.
White Lightning is very porous causing it to attract dirt and oil. So if you are concerned with aesthetics, spray it with high-temp paint (as mentioned above) for easier cleaning.
Ha, thanks again
I just looked at your location and saw you were from Rochester. I was born there and moved w/ folks to Baton Rouge when I was 5. Have not been back there since 10, 30 years ago. I have been meaning to get back again some time. Have fond memories from when I lived there.
I think Swain WL = VHT paint is the way I plan to go.
Steve
Steve
Ha, thanks again
Steve
Steve
I tried to get Swain to do a "group buy" for our club but they weren't real keen on the idea. They seem busy enough w/out having to wheel and deal.
Good luck with whatever route you take!
OK, boxed up and heading for Swain for the white lightning on the B&B header and SFR crossover. I will spray w/ a VHT paint when I get them back.
I started to pull the down pipe, but was running out of time at the shop I work on my car at, and did not feel like fighting the UR nut.
I was curious on thoughts for the Turbo and downpipe. I already have the downpipe wrapped, and have extra wrap I took from the header and crossover.
So I was thinking of wrapping both, and spraying several coats of the DEI high temp silicone spray to protect from oil.
I was more worried about the header and crossover rusting then catching fire, since thinner and more expensive. Plus more potential for oil as well.
I would think the wrap would help the spool at bit, but really keep the heat away from engine bay.
Comments on wrapping DP and turbo appreciated.
Steve
Steve
The ceramic coat is just an insulating layer, it isnt "directional". The shinyness is just for looks.
Skip the wrap... you really do not want to coat the inside and have fun with the finished product!
is there any problems with cracking when using the wrap? i've debated this for years but am afraid of cracking and such so i haven't used it.
also, for those using wrap, is there a noticeable increase in spooling?
FYI Jet Hot is having a 30% off sale if you ship your stuff out before July 4th
The black 2000 coating is the only coating that will stand the test of time....their sterling silver stuff can't take the heat these engines/exhaust systems generate
