Header wrap or Ceramic coatings
OK, since my plans have changed from dedicated track/DE car to street/DE car, I would like to hear comments on the subject.
I currently have B&B headers that are wrapped and a 2 piece SFR crossover that is not wrapped or coated. I also plan while engine is out to Insulate the turbo, so looking for suggestions there as well.
I have read many who feel that the wraps can cause fires if oil leaks are significant enough, and others who feel that if the wrap gets wet, it can cause rusting. I was planning to spray w/ the DEI silicone spray
or
Send to Swain and have the White Lighning coating applied.
Looking for anyone who has used both, or had problems or good sucess with either.
Steve
or
Steve
Seems to be 2 schools of thought about wrapping or insulation. Better to keep the heat in but can exacerbate welds cracking, so....not sure....
Well the biggest problem with the engine compartment in the 951 or just about any turbo car is the insane heat that the exhaust header\turbo makes under the hood. All that heat makes a higher ambient temperature that gets sucked into the intake, especially with our typical cone filter. As well as heating up other components melting the aos etc. If i had the ceramic paint available when my new turbo was off i would have sprayed the hot housing/downpipe etc. But afraid its to late for that now maybe next time.
I tried that. You have to be careful to not get fluids on the wrap. I used the blanket material that has a reflective coating that won't soak up fluids but when I pulled the cam tower oil got underneath so tons of smoke. I pulled it all off and just run with ceramic coat now.
Ever consider Jet Hot 1300 Silver? It will hold at higher temps, and cut down on avg, 180 degrees on exhaust, crossover and downpipe. Not to mention it looks great. Todd Beiswenger at Jet Hot if he still works there.
Open to all suggestions. If ceramic would like one that will hold up w/o flaking and which as the most heat reduction. I was under the impression that the Swain white lightning had the highest rating as it was thicker then the others. I had planned to spray a VHT paint on top, which they are OK with.
I like the idea of no wrap, since the possibilty of oil fire.
SKI how long have yours held up on the track?
Steve
Steve
It looks great but I went with their black coating because of the high turbo temps.
Personally i would go with the Swaintec. From my reading on 'teh interweb' the general consensus seems to be that Swaintec is a better insulation material and holds up bettter. The flat white is not as flashy as the Jethot coating, but i will say it does look 'business' on my friends car.
Take that for what its worth though, if all the armchair engineers floating around on the internet were as smart as they lead on we would have cold fusion by now.
Cost isnt too bad (in my opinion atleast), headers and crossover coating will run you around $400, probably less.
sorry, missed that it was on the track car, Jet Hot holds up fine on a street car and looks great. Mine was still in excellent condition when I sold the car, about 8 years on it. Track car, I'd probably go Swaintech but I would further help the heat by wrapping the crossover section under the oil pan and the exhaust by the axle
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Drive-by provocation guy
I had mine exhaust side ceramic coated, now about 5 years ago. No cracking or other problems.
Before coating after hard runs at night I could pop the hood and still see the headers a light orange glow. After coating there was no glow.
Also, there is heat disipating coatings that can be used especially on the IC/pipes, etc.
