OPRV in Head
OPRV in Head
I am not exactly sure how to install this valve/assembly. I followed the procedure in the Factory Service Manual to remove, but I can't seem to find how to install. Does it get pressed in? This is the last piece that is holding me up from getting the head back on. Thanks
Hey Man
Are you talking about the check valve in the head? Some info on model year and block number would help. The check valve and procedures changed between early and later production run 944 engines.
How is it pressed in? The manual does not say how to install just remove. My thought is to just use a socket that is the same size and use a dead blow hammer and lightly tap it in. I thought somewhere it would say how far to drive it in though.
