Clutch Slave Cylinder hell!!!!!!!!Update
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Just got done bleeding my clutch slave cylinder!!!!!! I knew it was gonna be aww tricky, but hey how bad can it be. I of course did a search and read about some of the issues, lots of good advice...of course, I ignored all of it!!!
I have a Motive bleeder so hey how hard could it be!
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Well as I read here the Motive can't get the air out from the CS, well by itself, anyway. So after jacking the car up and down, in the process dropping a heavy jack stand on my hand, then banging my head into the car so hard I was seeing stars!
I took a break to regroup, and days later, I got it done!!!! I did use the Motive on top and I used a hand pump with a tee on the bottom. It took two days of off and on work, to get that thing bled!!
Oh and I saw the post, too late of course, about filling the cylinder first before you mount it!
Yeah, right! Well in retro spec I would advise doing just that! Never ever put the CS on empty,yeah it's easier to mount it if it's not filled with fluid but you will pay for it when you go to bleed the system!!!!!
Oh and a note for those of you that have a Motive Power Bleeder, if you suspect
you have a hydraulic system fault,use the Motive to confirm!
After I had already pulled the slave and was trying to bleed the brakes, , with the Motive pressurized, I noticed a leak by the reservoir, you know that blue hose that goes up to the reservoir with the clamp on it? Yeah well mine had no clamp!!!!
Oh well I guess I'am done for now!
Um..![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
http://reutterwerk.com/forums/showthread.php?t=12834
I did it, took me 10 minutes to bleed the system... OH and it cost less than the OEM hose... Lets you bleed the clutch with the slave ABOVE the master...
Blue hose... sucks, put a clamp on it and see if it still leaks, if so get a new one (call a hydraulics shop for some brake fluid resistant hose, they will have it)
I had issues bleeding the clutch slave until I just unbolted it from the bell housing (everything else still attached) , put a little pressure on the rod, loosened the bleeder, pushed the rod all the way back into the slave, closed the bleeder, and released the rod... That got 95% of the air out
Yep part of the good advise I ignored! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Goopd Advise would have saved me days..but I bolted it on already,not taking it off again! Damm the torpedoes full speed ahead!
I tend to take the same approach, to hell with it, I'm all in...
good luck, hope it all sorts itself out soon...
It's all good, not a daily anyway so that takes the pressure off. It just seems that anytime I think oh well this will only take inset time here () minuets bam I run into more German Engineering weirdness!
I mean look at the whole exhaust/turbo setup!! WTF!!! I'am glad the Germans did not invent the wheel!!
I am a big fan of German engineering, they have great designs and generally build in safety factors, unlike some of the other manufacturers who's goal is simply cost out.
PS the blue hose doesn't really need a clamp as the only pressure it sees is the height of the fluid above it which is minimal. It only sees pressure if you use a pressure bleeder on the master cylinder.
I had issues bleeding the clutch slave until I just unbolted it from the bell housing (everything else still attached) , put a little pressure on the rod, loosened the bleeder, pushed the rod all the way back into the slave, closed the bleeder, and released the rod... That got 95% of the air out ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Great tip. This little trick works wonders and saves hours -- point the bleeder end up when you push the rod in, and be sure no one steps on the clutch while you have it apart.
Update, it was the hydraulic line! the car now moves under it's own power!
It's only gone one foot forward and one foot back but it did not do that before! Pedal was firm when it was on jacks but of course now that i put everything back together the pedal is soft!![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
So it's on to round two! I have to adjust the parking brakes anyway so I'll bleed the slave with the cars butt in the air this time.
Guess I just have a knack for making a simple job difficult! The secret is to learn all you can from others and then toss it all and blaze your own trail!
Maybe I'll take the starter off this time blindfold and with oven mitts on!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
