Oil pressure sensor wiring hookup
04-28-2010, 08:37 AM
How do I know If I hooked my oil pressure sender up right? It seems to be working fine right now , reading 5 bar.
04-28-2010, 11:01 PM
IIRC if it is wired wrong it will peg at max. I don't have mine hooked up right now and my gauge reads 5 all the time.
04-29-2010, 12:45 AM
^ correct.
When you turn on the ignition (but not start the engine) the gauge will either go to 0, or it will peg above 5.
04-29-2010, 09:43 AM
Ok, so mine goes to zero when I turn the ignition and once started it goes right to 5 so I guess its right.
