ER - control arm rear monoball clunk
Old 04-08-2010, 07:58 PM
jasonlp
jasonlp's Avatar
Default ER - control arm rear monoball clunk
Anyone ever experience clunking shortly after installing new elephant racing control arm rear monoballs?
Old 04-08-2010, 10:23 PM
tjbreen
tjbreen's Avatar
I have the ER monoballs and polybronze spring plates. I didn't notice any noise of any kind after upgrading.
Old 04-09-2010, 07:18 PM
ninefiveone
ninefiveone's Avatar
I have some clunking going on but I haven't had time isolate where the noise is coming from. Only change was the ER monoballs/bushings and coilovers.
Old 04-09-2010, 07:56 PM
snora
snora's Avatar
IF THE SOUND IS WHEN YOU ARE MAKING A TURN--CHECK YOUR EMERGENCY BRAKE CABLE--MINE WAS HANGING UP ON A PROTRUSION OF SOME SORT (I FORGET EXACTLY WHAT) WHEN I MADE A HARD LEFT HAND TURN- IT WAS THE RIGHT SIDE CABLE
SNORA
Old 04-10-2010, 03:03 AM
jasonlp
jasonlp's Avatar
SNORA
Clunk happens when Im just even rolling at low speeds in a straight line
Old 05-21-2010, 02:17 AM
jasonlp
jasonlp's Avatar
BUMP
Any new installs making clunk noises?
Old 05-21-2010, 02:27 AM
George D
George D's Avatar
Did you check your trans mount? That or tq tube bearings is my guess. I think it's your trans mount sans the stock rubber. When you take the rubber out of your suspension, other items without dampning become noticed.
Old 05-21-2010, 10:55 AM
jasonlp
jasonlp's Avatar
Sounds directly at the monoball. You can use prybar and or bounce test same reuslt. Just for extra, my trans mount is polyurethaned. I even had the monoball switched sides and the noise follwed the monoball, then I bought another one because ER thought it was impossible that it was their piece and the new one makes the same noise. So 1of 3 is silent...
Old 05-21-2010, 11:39 AM
jasonlp
jasonlp's Avatar
Here is quitter version of the sound it can be louder
File Type: zip
Old 05-22-2010, 11:37 PM
Musche
Musche's Avatar
I had a set that I sent back to have rebuilt since the driver side had worn out and the wheel would move about 1/4 inch back and forth when I would torque the lug nut. I got the new set the other day and have the same noise that sounds like a "snapping pop" when the car/suspension moves up and down. I may take them off and see if I can figure out what is going on. I noticed when I put them on the center section was very tight. I needed to put a crescent wrench on the housing to get it adjusted so I could put the bolts in. The last set I had moved freely with just hand pressure. I'll let you know what I find out.
Old 05-23-2010, 12:10 AM
jasonlp
jasonlp's Avatar
Snapping pop is right! Drives me nuts.. New one is quitter but still pops
Old 07-06-2012, 05:02 PM
dlr944
dlr944's Avatar
any news on the fix for this? getting ready to install mine.
Old 07-06-2012, 05:27 PM
jasonlp
jasonlp's Avatar
Yes there is!! Pull back the weather seal and use Wurth HHS-2000
2 years no more noise =)
Old 07-06-2012, 08:40 PM
95ONE
95ONE's Avatar
Weather seal!? wha?
Old 07-06-2012, 08:42 PM
jasonlp
jasonlp's Avatar
Originally Posted by 95ONE
Weather seal!? wha?
Weather Seals - Our proprietary-design Monoball cartridges have weather seals to keep dirt out and extend product life. This is the only Monoball suitable for street or extended track use. Dirt and water contaminate ordinary products and accelerate wear.
http://www.elephantracing.com/suspen...dmonoballs.htm
Quick Reply: ER - control arm rear monoball clunk
