ER - control arm rear monoball clunk
Old 07-06-2012, 09:14 PM
dlr944
dlr944's Avatar
Nice to know! thanks for updating this thread.
Old 07-06-2012, 10:32 PM
jasonlp
jasonlp's Avatar
Originally Posted by robstah
Sphericals don't need grease. If anything, that could make things worse. I would be worried about extra slop if you were hearing a clunk. The grease might just be dampening the sound and movement. The last thing you want is dynamic caster.
I went through a lot of back and forth with ER and this was the cure all solution. This only applies to new out of the packaging monoballs, if your having issues after then it's a whole other problem.
Würth HHS 2000 is a high pressure, resistant adhesive lubricant. It lubricates parts exposed to strong pressure and impacts on vibration. Würth HHS 2000 is silicone free, highly polymeric and penetrates quickly and adheres completely. Würth HHS 2000 is fluid, non-sticking with an excellent creeping capacity which penetrates into inaccessible places.
The solvent in Würth HHS 2000 evaporates as it is sprayed resulting in an immediate strong adherence of the lubricant onto metal. It is ideally suited in places where mineral oil and other lubricants do not achieve long term effectiveness or where parts must be dismantled when applying lubrication paste. It also has long lasting effectiveness in places which cannot be lubricated in short term intervals. Sprays on as a liquid and then dries to a clear semisolid which will not dry out. Würth HHS 2000 is water resistant, will not attract dust and will not damage rubber.
Old 12-25-2023, 09:46 PM
964-C2
964-C2's Avatar
Originally Posted by jasonlp
Yes there is!! Pull back the weather seal and use Wurth HHS-2000
2 years no more noise =)
How is it now...?
Quick Reply: ER - control arm rear monoball clunk
