Have fuel and spark, no start!? long, sorry.. *SOLVED!*
here's the latest. I pulled the plugs and took a pic. Keep in mind, these are brand new plugs and, since the car has not started with them at all, they have only been used in the attempted starting (turning over and not firing). from left... 4-3-2-1...
what do you guys think? They seem to have fuel on them and even maybe sparked off a bit and burned...timing?
I had a similar problem. Rotor set screw had backed out and rotor was slipping on the shaft. Car would spark, car had fuel but would not start. Rotor was spinning on the shaft but the timing was way off and thus never fired.
Suggest you verify the rotor is tight onto the shaft.
I have no idea why Porsche didn't put a flat spot on the rotor shaft like just about every other manufacturer.
Okay, I checked everything again and this time let it crank for a bit, twice. (8-10 sec each, maybe?) At the end of each cranking session she popped a little out of the exhaust. other than that, nothing. is that anything? I'm ready to tow it out into traffic and take an insurance claim...alright, not quite yet, but getting there...
Defending the Border
Rest In Peace
Rest In Peace
so my wiring has definitely been 'modified'...unfortunately, not by me (PO)...so I'm not intimate with the wiring.
I did replace the ground cable...maybe I jostled an already bad connection back there? A couple of the three prong connectors look mickey moused together... truthfully, I'm not even sure what all the connectors go to back there. Is there a good detail of that area for wiring explanations? I also re-wired the plug on the icv..very straight forward, though.
hp18, unfortunately, I didn't do anything with the speed/ref sensors. Is it possible just working around them messed them up? Maybe I jerked a wire while I had the intake off that went to something in there? I did clean off the ground area when I replaced the cable, and used a little PB to clean up, along with a little wire brush....any problems there?
I appreciate all the help here. I'm so busy and this really throws a wrench (no pun intended) into my life... We'll figure it out...or I'll have a psychotic episode..;-)
Also, if anyone wants to come out this weekend (if I can't figure it out before then), I'll pay what I can for some help...so embarassing...I rebuilt my whole 74' Land Cruiser and can't get this stupid ignition problem figured out...grrrrrrrr...
+1 on the speed and reference sensors... they seem to have a mind of there own when they are going out. it's surely worth wiggling them and having someone turn the key to see what happens.
I'll check them tomorrow.
I was reading on Clark's about the fuel pressure being too high and shutting down the injectors. My rail gauge is dead, so I think I'll replace that and see if my pressure is messed up as well..
Does anyone else find it odd that something major would break while I had this stuff apart? It seems more likely that I did something while I was in there...Or it's just Murphy's law. What a pain.
Wow...take a look at the connections for the speed and ref sensors...this can't be good. And yes, that looks like goop filled in the end of them to hold the wires in there...I want to hurt someone..
Can I just hard wire them to see if it'll start, then wire in new plugs?
jblobner (03-01-2022)
Yeah, just checked paragon. I'll get the harness from the dme, also...that whole thing is an abortion. Hopefully that's the problem, too..
Edge, I'll have to crank it again to check tach activity. What should it do when cranking?
