Stock Altenator alternative?
I tried the nissan alternator, its not exactly a bolt in procedure. Be prepared for some cutting.
I second Luis's opinion on getting the alternator rebuilt. I never charge more than $125 to rebuild an alternator. Just remove it yourself and take it to an alternator/starter repair shop...or take it to a regular shop with an older owner.
A good elec. auto shop will rebuild your alternator for much less than any other alternative. This is what mechanics used to do, fix whatever broke.
I have a nissan alternator, but I needed a smaller alternator to clear my turbo and exhaust downpipe. You need to purchase a proper kit, and wire it up properly.
https://rennlist.com/forums/944-turb...eted-pics.html
There are kits available. You have to make sure that the belt lines up PERFECTLY with the new alternator.
the quest alternator was easy. I just had to grind down the tabs on the alternator itself to get it to fit. Nothing else had to be modified. if you dont put a quest alternator in your car your a idiot and if you need a kit to do it then your still a idiot.
The issue we had was that the pulley's didn't line up perfectly. There was some side rubbing because of the slight offset. It would have worked fine, but I wanted it perfect. First time I've been called an idiot, so thanks.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
