Wasted Spark System
#63
Using a COP is doable, they just fire in a wasted spark form.
When using a different coil or COP, there are a few things that must be known, like the dwell/charge time for the particular coil as well as the shape/type of signal it handles. For now, to keep things simple and to keep the cost down, we are looking at the coil-pack. If someone must have COP, we can handle it as a special project, which will be time consuming and will drive the cost up.
#64
A quick update. The new WS system is up and running on my car. The next stage is to figure out the packaging and the cost.
Thank you for the input!
#66
Based on everyone's reply, more than likely the new WS will be modular. A base model with no ignition control, then a advanced model with ignition control.
Both systems will require you have a Vitesse Gray PiggyBack and chip/board (which will need to be reflashed). The base system will be $500 or less (assuming enough people are interested).
#71
I would rather say that having to immobilise the car for a period depending on the efficiency of aerial postal services is a right pain in the back.
Anyway, pleased to know the WS will be availbale soon - you can put me on the list John.
#72
Trust me, I'm not too crazy about having to reflash the chip/boards either. However, for technical reasons, the software must be changed for the new WS to work..
#75
I got the prototype working, with a few minor changes needed. Working on a way to bring the price down sub $500.. However with the limited demand, I'm not sure it's possible.
