x-post: water pump and belts video tutorial
I have to fix a leaky water pump, so I thought that while I did it, I'd take some video and make a tutorial.
Disassembly part 1:
Disassembly part 2:
Reassembly videos will come later (maybe in 2 weeks).
Disassembly part 1:
Disassembly part 2:
Team Owner
Just wondering but will you be using the factory 920, Arnworks or Kriket to set your belts? I've had engine on the stand for over a month now with new belts and rollers. Been bashful about setting them. Bought a Kriket been playing with.
The balance shaft belt I just set by feel.
It takes some getting used to, because you need to learn to reset it properly between tensioning attempts, but it has such a broad measuring range that you can really hone in on setting the tension required.
