Part # for plastic clip that holds electric wp plug?
There's a black plastic clip that snaps into the top of the electric waterpump bracket (right next to the A/C low and high lines, which are also clipped to the bracket). It secures the plug that connects the electric turbo wp to the wiring harness. I cannot find this part pictured in the parts diagrams for the life of me. Sadly, the waterpump support bracket is right there on illustration 105-10, but the plastic clip that attaches to it is not.
Anyone know what the part number is?
I believe that the clips for that plug is the same clip that is used for holding the plugs for the brake pad wear sensors, and the O2 sensor. Unfortunately, Porsche has a bunch of different part numbers for those clips depending on the model of the car, although I think all the wear sensors use the same plug. I'm finding:
999 651 202 40
999 651 203 40
944 612 635 00
You could always check on your own car and see if any of the existing clips work. Maybe they'll even have a part number molded into them. Hope this helps.
999 651 202 40
999 651 203 40
944 612 635 00
Special care is needed when removing the old clip and refitting the new one. These have a plastic peg in the middle that is pushed through the gap in order to hold the clip snugly in place.
You can easily break the clip or bend the mounting plate when doing this, so you may want to get more than one unit! I found it best to use channel lock pliers with something over the peg for leverage.
