Stripped the glide plate allen screws on caliper
Old 03-13-2011, 11:10 PM
  #61
Crazy Eddie
Crazy Eddie's Avatar
Originally Posted by AOW162435
Has anyone identified a source for these pad slider screws? The PET shows the screws available with the actual slider, but not separately.
Andreas
Pretty much any good bolt place should have them
Just to name one or two
Global Metric
Global Metrics Inc (Metric Fasteners Center*)
519 Marine View St # J
Belmont, CA 94002-2568(San Francisco, CA Metro Area)
Phone: (650) 592-2722
I believe they are M6 x 12 They have them in black oxide ( I have mine plated in yellow zinc ) they ave the clear zinc ( sliver colored in M6 x 10 only not the 12mm)
I have both, but used the M12 ones ....
There is also a place on the east coast you could try Bel Metric, they have a boat load of stuff.
They are called cap head's ...
Hope that helps
Regards
Ed
Old 03-14-2011, 01:16 AM
  #62
AOW162435
Seared
AOW162435's Avatar
Ed,
I just found and ordered the screws from McMaster-Carr:
M6 x 12
Andreas
Old 03-14-2011, 02:21 AM
  #63
Crazy Eddie
Ed,
M6 x 12
Andreas
It's hard to tell from that drawing, but they may be tapered slightly differently .. I don't think that should be an issue though....
You will have enough for two cars and then some ...
I don't know whether to tell you to get the 8.8 or the 10.9 hardness Only the 8.8 are zinc plated, and my guess is that they are clear(silver zinc ?). I assume you already pulled the old screws out ?
Best regards
Ed
Old 03-14-2011, 09:42 AM
  #64
AOW162435
Seared
AOW162435's Avatar
Yes, the old screws are out and the heads are pretty rusty.
Andreas
Old 03-14-2011, 04:46 PM
  #65
Crazy Eddie
Andreas
Their out ???!! I didn't hear any cursing! How could that be ?
You must be either a very lucky man or master with the tools
There was approx a tube of loctite in each of my screw holes
Good luck
Regards
Ed
Old 03-14-2011, 05:15 PM
  #66
AOW162435
Seared
AOW162435's Avatar
They were snug, but they all came out with deliberate pressure. T-27 Torx, and a 1/4" ratchet. And yes, they all have the white-ish threadlock coating.
Andreas
Quick Reply: Stripped the glide plate allen screws on caliper
