Stripped the glide plate allen screws on caliper
Has anyone run into this and if so how do you remedy...?
Standard approach is to drill it out, but this is a very small area (I don't think I can get the angle needed, to drill it out head on??
Any ideas, would be welcome
Just a thought, not based on any type of experience, but can you cut a groove across the bolt head with a dremel and use a large flathead screwdriver to torque it out?
Whenever I've stripped out allen head bolts, I'll beat a little bit larger Torx socket into place. A cheesehead (12 point) doesn't seem to work as good as a Torx.
If that won't work, I'll weld a hex nut on top.
Drilling is always my LAST resort.
It's in such a $hi%^ position, that's really hard to get to, except with a Dremel ...
Ed
And sadly, there really very little room to hammer anything into it ... Because of the angle .... Otherwise I would try that ...
As for the weld ..Hummm I may have to call in the reserves ....
Hey Tom, got that MIG welder handy
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
I don't think a dremel is going to work in this situation. It may, but even if you get a nice groove cut, the screw driver isn't going to give you much leverage and will probably just slip out of the groove.
I dont even know if I can drill it out because of the angle it presents...
Hey Tom, got that MIG welder handy![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Basic Sponsor
that looks like a turbo S caliper. what were you trying to do?
You'll need a set of extractor bits, and choose one just large enough to fit in the allen head. Then tap it in gently with a hammer and use a suitable wrench on the bit to make it turn.
