Flow Bench
Flow Bench
You gotta be a rocket scientist to do this s#$@....
I think I'll stick to polishing
If i had needed a flow bench i would have made one years ago they are a piece of cake . you can also just dump water through an inlet port and time it for comparative flow tests .
I'm always baffled why hardly any head shops have them ...there realy is nothing to them ..
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Everybody is squeamish about measuring gasses....they measure liquid all the time.
Air measurement just has different pressure scales and most people don't have the equipment to measure it.
Formula One Spin Doctor
LOL ......
Briefly scanned through the links. I didn't see any mention to calibration to compensate for barometric changes, heat rise, plus a few other variables that must be taken into account to figure out the actual flow.
When using a flow bench, more than likely you will flow the same head over a period of time. Flow, port, flow,... So unless you can account for external variables from one day to the next, the results will not be correct and will be impossible to compare results.
In addition to the flow bench, a few other tools are great to have: swirl meter, velocity probe.
