reinstall turbo tips
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
I'm having to do this myself and having a hard time with it. For one, how does someone, by themselves get the two turbo mounting bolts back in? I'm thinking I may have to remove the alternator so I can get the short one from the top and hopefully that makes the other one easier. That and get a short screw driver to encourage the crossover and turbo to align while I get a bolt in for that.
Also, does anyone have that nice parts list that came with the exaust bolt kit that was available several years ago that they can send me? I lost mine and having a bit of trouble sorting what goes to where for some of the items.
I literally just did this 15 minutes ago....took me about an hour! I got the short one in pretty easily but then took about 45 minutes trying to get the long one in. What I did was take a bungee strap and hook it to the compressor housing and hang it over the bumper. I could then wiggle the turbo by pulling on the strap and finally get the long bolt in.
Here's the bolt diagram for the Rennbay kit i bought (same thing you're talking about?)
![](http://i14.photobucket.com/albums/a303/alxdgr8/0318100059.jpg)
![](http://i14.photobucket.com/albums/a303/alxdgr8/0318100059a.jpg)
And after all the cursing and busted knuckles you get to sit back and enjoy the beauty!![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
![](http://i14.photobucket.com/albums/a303/alxdgr8/0318100059b.jpg)
I may have to drop the crossover, it's making it hard for me to align the short mounting bolt hole. I don't think it was the Rennbay kit but what you posted does help. It looks like the Rennbay kit and mine have a lot of washers that can't be used because there isn't enough room though.
^^Same here. I think it would have been a lot harder to do with the crossover bolted up. I have AC delete and I still took my alternator out to make things easier.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you think you are ever going to remove the turbo again it is really worth getting the 2 piece crossover mod – it comes in very handy!
Loosen the steering rack and pull away from crossover approx. 3/8", you'll be able to get to the short one by using a long extension between the rack and crossover. You'll need a swivel. Start the short one and if the long one doesn't go in, adjust (move slightly) the turbo and try again. I just did it this way and it worked perfectly.
Steering rack has been detached from the crossmember when I removed the turbo, helped a lot. Loosening up the crossover worked.
Turbo mount bolts are in place and the downpipe is connected to the exhaust. I misplaced a wrench so couldnt use the double nut trick of removing the studs so I can switch out my headers so off to get a couple new tools. I also need to replace the oil sender as one terminal post turns freely so I cant get the darn nut off to attach the lindsey wiring harness. But at least some progress today.
Unfortunately, rental car costs and other things made getting the 2 piece crossover mod not possible right now. If I could I would do that and the crossmember. Oh well, perhaps in the future. When all is said and done at this point, I'll have a thermal coated and wrapped headers, downpipe and the crossover wrapped at the brake booster area and numerous oil leaks fixed. It looks like some were so old they caked over and didn't leak anymore lol
