Pauer Tuning/ Wastegates
Thanks for the replies, only issue I seem to have is getting a consistant boost setting, sometimes a little low, other times a little high in spite of similar weather conditions, I wonder if the dual port would sort this out ?.
Single vs Dual port mode should not make a difference in how peak boost is held, main purpose of dual port is to close the wastegate more quickly when releasing the throttle while upchanging gears, so that the turbo reloads as fast as possible when flooring the throttle again in the next gear.
I used an as new, 3mm shimmed factory wastegate just before moving to the Tial in single port mode with a 1.0 bar (blue) spring, I couldn't feel or see any difference.
The dual port mode allows the use of an EBC to adjust "boost ramp", which I don't think is possible in single port mode.
blade7, what do you control boost with?
Single vs Dual port mode should not make a difference in how peak boost is held, its main purpose is to close the wastegate more quickly when releasing the throttle while upchanging gears, so that the turbo reloads as fast as possible when flooring the throttle again in the next gear.
I'm not too sure, seem to get full boost just after 3k and no problem holding whatever I set it to initially, which is why I hadn't gone to a dual port yet, it's just the inconsistency from day to day, 15 psi and 20 psi seem fine between isn't despite minute adjustment on the MBC.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Vic is a great guy, and provides great service. I have his kit as well, but modified with Stage 8 locking fasteners. Posted pics about a month ago if you want to take a look. It made a huge difference, from my shimmed stock gate. Total different car, rock solid boost.
A good option, just a pity there's a 30% premium for me to import it.
