Cream colored oil...
Ok other than a HG what could be causing this? I pulled the hard pipes to start fabing up new ones and they had a water oil mix pooled inside. Checked the oil dip stick and it is cream colored.
The car does not over heat but has excesively used coolant for a while, I could never find the leak... No smoke, and the car ran great...
87 951
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
87 951
On N/As they had the internal oil cooler element that could cause this, but I don't know if it can on the turbos due to the oil filter housing. I don't know where else the oil and coolant are close enough to mix outside of the headgasket...
Basic Sponsor
blown hg.
Wax On, Wax Off
it's definitely oil cooler seals. on the N/A it's got a core like a radiator. on a turbo, it's a bypass to the external oil cooler, but there's still an O-ring in the mix. that's gone. so do that.
You said it's been excessively using coolant for a while, I'd assume your bearings would be damaged now. I'd see about changing those too..
Sorry about that. I could be either the oil thermostat seals or the head gasket. In my HG R&R write-up, I list tips for figuring out if it's the HG. See this link:
http://members.rennlist.com/tom86951/headgasket.htm
The most reliable test in my experience is to trap the coolant overflow hose in a plastic bottle and go for a drive. If it overflows when you are on boost, but not when you drive gently, that's a pretty strong sign it's your HG.
If it turns out to be the oil thermostat seals, I did I write-up for that here:
http://members.rennlist.com/tom86951..._seal_repl.htm
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
I might just take you up on that.
Hopefully that will be the problem, I also have to address the turbo soon.
Ugh damn me for saying how reliable these cars are.![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
The car has been parked for 2 months now, oil looked fine then. I started it got to temp just to clear the cob webs out and that was all.
The oil looked fine when I parked it.
Coolant tank and exhaust was normal.
Coolant tank was very low though.
X-reply...
Parked for 2 months, with the weather we have been having, could be condensation in the crank case... Change the oil , run it a LITTLE, and change it again... water / coolant will eat up the rod bearings if it is run TOO much...
