WTB: Lindsey Racing Mafterburner
Looking for a LR Mafterburner kit, preferably used but working/good condition so I can save a few dollars. Can't afford it brand new unfortunately.
Or any similar setup or software that can help me fine tune to the LR MAF kit / setup.
Thank you!
Thank you!
I have a Split Second piggy-back I got with my Speed Force Racing MAF kit a while back for sale cheep. I made a reliable 300hp with that.
I also have a MaxHP Maxtronic chip emulator that I will be pulling out this spring that I will be selling.
Both are good options. Let me know if you're interested.
not to mess with robs deal on the split second stuff. it works but safc-2 and neo have more tuning points, I know my neo has 16 points when the split second has only 4. safc-2 100$ awesome deal. good harness length is important as well.
Hey Dude, did you get my note on the other thread?
ahhh good thinking its just hard to get used to using you know those japanese people. you wire it into a few wires on the dme harness and 1 wire in the klr harness. 7 or 8 total i think. look on ebay for a neo. i got mine there brand new never used for 250 shipped. neo has decel option on it which lets you run a BOV to atmosphere. do a search type in safc2 wiring look up thread by caster951. then for detailed wiring diagram for the car do search for dme wiring there is a good thread there somewhere.
Thanks for all the offers guys. I'm a little bit inexperienced with these electronics so I'm not sure what half the stuff you guys are offering even is, but so far I have had a couple offers on different setups for $100.
The main reason I'm looking for the Mafterburner specifically is because I know someone with experience installing and tuning it. If the other brands are essentially the same then I guess it won't be too big of a deal.
All PM's replied to thus far!
Yep I believe so, did you get my reply?
Drift & Spyder, Its the Split Second P1SC-004. It worked well. I got it with the data logging option as well so I could log my AFR. I'd be happy to let it go for $100.
http://www.splitsec.com/products/psc1/PSC1004.htm
Spyder, not sure what you mean by "only 4 points"? The P1SC uses the Split Second R4 software which uses a huge table/map in 500rpm by 0.5 volt increments. Check it out.
http://www.splitsec.com/products/datapdfs/R4DS-1.pdf
