Turbocharger Nomenclature
I'm trying to decipher the Turbo "name game"
Example - Kokeln Stage V turbo.
Specs: TO4B, 60-1, Stage 5 (T-350), #8
Meaning ( I think ) : Turbonetics TO4B cold housing with a 60-1 (61#) compressor wheel - Turbonetics Stage 5 turbine (T-350 is the "style" of the turbine ?) inside a turbonetics made KKK #8 replica hot housing.
How did I do ?
How did I do ?
its no accident the names are bewildering
just get one of these ... no translation needed .. proper names according to what they realy are
http://www.034motorsport.com/index.p...so7qel733cbt3a
I like this one:
http://www.034motorsport.com/product...so7qel733cbt3a
Why do you like the one that you linked?
Since 034 makes primarily Audi stuff, then I'm 99% certain it won't bolt up. Audi turbos just hang from the exhaust manifolds and then have lines going to the oil/coolant hookups. Unlike the 951, which actually mounts on the oil return. If you read up about ball-bearing turbos on 951 you'll know why this is a problem and why it won't bolt up.
How did I do ?
How did I do ?
Anyway, the "Stage" is their turbine side. The numbered ones are from their T3 series. Most of the time when you see them mixed (generally referred to as T3/T4 hybrids), they have State III's. Stage V is freakin' huge.
Regardless, this turbo is a monster. Hope you aren't thinking of putting this on a stock 2.5L.
"Regardless, this turbo is a monster. Hope you aren't thinking of putting this on a stock 2.5L."
Too late! It's been on there for about 6-7 years ! Put down ~320 to the wheels. But I would like the fastest spooling turbo that can hold 16 psi to redline and make 310 whp.
Anybody have the answer ?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Turbo nomenclature –
The ‘cold’ side in the front sucks the money in and the ‘hot’ side chews it up and spits it out the back.
When you run out of money it stops.
601, 621, 944, kkk, kokeln, names, nomenclature, porsche, specs, stage, t04, to4b, turbo, turbocharger, turbochargernomenclature, turbonetics
