notchy clutch pedal
I noticed a couple weeks ago that my clutch pedal has developed a "notchy" feeling.. which I suspect may be the needle bearings on the clutch fork. Other than that, the clutch feels pretty good and I've never had it slip or anything. I don't have records on it being replaced but the previous owner claimed it was done recently. Is there any way to shoot some grease into those bearings or am I looking at a total clutch job here?
Wax On, Wax Off
Sounds like your diagnosis is accurate. and yeah, it's a bellhousing off job...
Edit: just remembered, the pivot pin might be notched too. I have pics at my computer at home... that's $30.00 and at most it's "starter/slave cylinder off".
edit 2: https://rennlist.com/forums/944-turb...ghlight=clutch found the pic, and associated thread.
Sure it's not the hydraulics? When the hydraulics first start to leak, it develops a little sticky/notchy point about an inch or two from the top of the pedal travel.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I've learned never to say "definitely" with regard to any problem described on this board. Just when you're confident some guy has a bad CV joint, he finds a zebra wrapped around an axle making the noise....
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
