Oil Catch Cans
#31
Drive-by provocation guy
#32
As the stock unit just routes the oil vapor right back into the intake then it is not really "separating" is it?
Also, do you not suggest a breather?
#33
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The whole concept of the stock system is that the crankcase can be under a slight vacuum – this is a good thing for ring seating and oil drain back from the turbo. If you take the oil filler cap off a stock engine while it is running you should notice a change in the idle – the same thing will happen if you run an open breather.
Also important to note – I believe that if you are really cranking out the oil vapor then the engine needs internal attention….just trying to fix it with catch cans is not really fixing the problem.
#34
any turbo car driven hard needs catch can keep the octane of the fuel up. especially bigger turbo users more boost my blowby gas. stock aos can barely handle 26/6
#35
todd off topic but got in touch with a great piping fab guy last nite specializes in evos and r32/r34 skylines does amazing work. my bet it can make some sickkkkkkkk 951 pipes. exhaust IC pipes intake. Im going to give him all the dimensions of everything and see what he comes up with. ran by last nite was running dyno on a twin turbo viper. 1050 rwhp. 1 day fabbed split intercooler system get more air flow to radiator to cool engine temp. 1050.....8hours later 1222rwhp. the dude is awesome. point being let me know if you want anything that you cant seem to find.
#36
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
A 20+ year old engine is a different matter...!
#38
Freedom Enthusiast
Not really true. A 944 turbo in good health will not have an oil vapor / blow by issue. A lot of the engiens I do use the stock AOS system with a blow off vlave vented to atmosphere - and no oil vapor coem out at all - even in 3.1 race motors at the track.
#39
#41
you want a vac. on the system just venting wont pull the crap out of the crankcase like it should. venting would keep it out of your intake but maybe cause a mess where the vent is and cause oil leaks else where.
#42
Let's say at idle, oil filler cap off; one should feel air coming out, but dry?
What should you see and feel when reving it up a little?
