Oil Catch Cans
Drive-by provocation guy
I don't think you could do it without removing the intake, but that is fairly simple once you have done it a couple times.
What you are plumbing back into the intake is clean air. There is a stainless steel wire mesh inside the catch can that the incoming air filters through and the water vapor/oil vapor condenses on the mesh and drops to the bottom of the can. I'm no expert but it seems to work and I believe this is how most, if not all catch cans are plumbed other than ones that vent to atmosphere.
So this would not act as a crank case breather in helping to elminate blow by with pressure release, but just "catching" blow by?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you have an engine that loves to spit out its oil here is my favorite solution -
http://www.moroso.com/catalog/catego...?catcode=13400
When installed correctly it has its own drain return to the pan
In reality I prefer to fix the engine so it does not spit out oil!
Looks like there are some other options out there in terms of plumbing as Chris White has indicated above.
Rocket Scientist
I'm just here to show off what I did. This can started life as a saki-a-chu-chu can or whatever. A bit fancier now.... (it is very important to recirculate the catch can back to the intake in my experience, and don't waste money on a can that isn't baffled because it isn't doing much) ....
DDP...looks like a nice set up, plumbed similar to my AMW can minus the AN fittings.
Do you have a pic of the baffle or inside of the can, I am curious to see how they differ.
Here is the AMW in two...
Nice clean install DDP what size line are you running out of the AOS delete plugs? I was thinking about just going straight -8 on mine, and I also was going put some fitting on the cam cover to pull some vacuum there.
Rocket Scientist
mj- The sac can doesn't come apart unfortunately. No pictures of it inside.
Tim- -8 for those lines. Drawing from the cam would be neat, the engine in the picture has a custom cam cover that probably could have been made to accept an AN fitting to do so. However, I think that'd be overkill and I prefer to keep things as simple as possible.
In case anyone is questioning me, it is not overkill to use AN fittings on a catch can.
OH and BTW, someone stole ur AOS... that catchcan ain't huked to nuttin..
Breathe dude, I'm just messing with ya.. looks good, even if it is a little dirty in there..
I have my SM in almost the same place, plumbed into the AOS and intake..
And for those who have wondered, I thought there was a cutaway pic on their site somewhere..but this drawing will have to do for now..
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The hose can be removed from the top of the AOS without removing the intake. You just need either a very short screwdriver or a very long one depending on where the clamp is situated.
The SM is the easiest/best/simpliest solution for most stock 951 engines since it already has the correct size hose inlet/outlets and has a tab for easy mounting to the stock cruise control mount. Cans without baffles and ones that don't recircuate are worthless.
If you email SM he can also make your can with whatever AN or other fiting you require if you don't want the standard clamp on style and it doesn't cost much more.
Rocket Scientist
