350whp on 92 octane - How do I get there?
Old 12-12-2009, 04:53 PM
  #76
951_RS
951_RS's Avatar
Hmm, now I want to know what sort of pressures my exhaust is seeing.
Old 12-12-2009, 05:07 PM
  #77
David Floyd
David Floyd's Avatar
Originally Posted by pjburges
What's a good way to measure exhaust back-pressure? .
Emissions test port in crossover pipe will work
Old 12-12-2009, 07:54 PM
  #78
TRP951
TRP951's Avatar
Yep thats a great spot since its already got the bung on it. Ive measured some pretty low back pressure running a #10 hotside with 3" dp and exhaust. Now I will be running a T3 0.82 housing and a slightly enlarged crossover modified to fit the GT turbo
Old 12-12-2009, 08:28 PM
  #79
V2Rocket
Rainman
V2Rocket's Avatar
what would be an ideal number for exhaust pressure? are we hoping for a vacuum?
Old 12-12-2009, 08:33 PM
  #80
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
No vacuum in a turbo car...
An ideal pressure would be less then 1 : <1 (intake vs exhaust).
But that won't happen without a huge turbine side (lots of lag).
Good would be 1 : 1.5
And acceptable is 1 : 2
-Rogue
Old 12-13-2009, 12:45 AM
  #81
pjburges
pjburges's Avatar
I wouldn't say there is any ideal number. Take the cat off your N/A car and go drive it around dumping at the headers. It will run like hell. Loud, but not good. With turbo cars it's somewhat of a different ballgame. Exhaust backpressure and the manipulation of it effects the torque curve of an N/A car. For a turbo car, its as mentioned above (to the limit of my knowledge).
Old 12-13-2009, 02:05 AM
  #82
V2Rocket
Rainman
V2Rocket's Avatar
i have wondered what the 944 would sound like with a straight pipe all the way to the back of the car. i have heard it open headers, that **** is loud lol
Old 12-13-2009, 02:14 AM
  #83
Rogue_Ant
Rogue_Ant's Avatar
Too loud.
Old 12-13-2009, 03:08 AM
  #84
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by Rogue_Ant
Too loud.
maybe just a large diameter pipe, no cat, to a turbo muffler then...
Old 12-13-2009, 03:09 AM
  #85
V2Rocket
Rainman
V2Rocket's Avatar
-Rogue
think those are good rule of thumb ratios for a supercharged car? only reason i ask is the lack of a big restrictor in the exhaust flow(turbine)
Old 12-13-2009, 07:16 PM
  #86
Rogue_Ant
Rogue_Ant's Avatar
No, a supercharged car will not have the same amount of backpressure to contend with. In fact, cam/exhaust selection with a supercharger is more similar to an NA car then a Turbo one.
For a mild supercharger application (yours), I suggest running the stock turbo exhaust (without a cat if possible). The stock turbo stuff is 2.5" with a straight through muffler - perfect setup for cheap.
-Rogue
Old 12-13-2009, 08:17 PM
  #87
V2Rocket
Rainman
V2Rocket's Avatar
i wish i could lose the cat (and all the other emissions crap) but cali says every year emissions testing soo...
i will look into the turbo catback though.
Old 12-13-2009, 09:29 PM
  #88
CarbonRevo
CarbonRevo's Avatar
Spencer- Friend had a catted 951 with no muffler. 112db's...
Old 12-13-2009, 09:39 PM
  #89
V2Rocket
Rainman
V2Rocket's Avatar
OMG lol
Old 12-13-2009, 09:47 PM
  #90
Rogue_Ant
Rogue_Ant's Avatar
And an NA would be even louder... No turbo to help muffle the exhaust.
-Rogue
Quick Reply: 350whp on 92 octane - How do I get there?
