oil squirters or drilling oil hole on the rods
12-05-2009, 06:02 AM
Quote:
Originally Posted by
fortysixandtwo
Yes, the 968 has oil squirters from the factory, and yes they are pressed into the block.
Ok, but if they are pressed into the block, has from factory a pressure valve
to open from a fixed pressure?
12-05-2009, 08:00 AM
AddictRennlist Member Rennlist Small Business Sponsor
ajrlredondo
Yes, each squirter has a check valve built in that closes at lower pressures.
12-05-2009, 01:57 PM
Magic Number?
Chris White
And yes, you can buy them separately if you know the magic number and where to order them. Of course you usually have to wait for them to get here from Germany!
Where do I get the magic number so I can purchase some for my block?
thanks,
-BB
12-05-2009, 02:10 PM
Anybody look into the squirters found on some vw applications as a possible other source?
12-05-2009, 08:31 PM
There´s a dutch vendor that sells the squirters,
If someone is interessted I could contact them and ask more info on the squirters
12-05-2009, 08:50 PM
I am...
Yes please check I am interested..
thanks,
-BB
54 ,
944 ,
check ,
diy ,
drilling ,
fuel ,
oil ,
piston ,
pump ,
side ,
skirts ,
squirter ,
squirters ,
turbo ,
valve ,
vw
