oil squirters or drilling oil hole on the rods
My question is what is better, oil squirters or drilling oil hole trough the center of the rod or both for a 951 engine that I´m building. And the oil pump has enough flow to both options??
Thank you very much in advance
Basic Sponsor
Oil squirters cool the pistons, rifle drilling the rod lubricates the pin.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
And yes, you can buy them separately if you know the magic number and where to order them. Of course you usually have to wait for them to get here from Germany!
hmmm 944 blinkers on .....
many engines have a .020" hole drilled in the rod not up to the gudgin. but as a "squirter" up into the skirt .
also if one puts a notch in the side of the top of the big end it will squirt oil up under the skirt as found in a BMW engine also this way you wont compromise the oil pressure in the mains or big ends . yes I'm aware of the 4 bar check valve in the squirt er i would just prefer to prioritize my oil system i bit more.
