building a new head
1 Post
building a new head
I'm starting to build a new head since I have the dreaded ceramic damage on my current head. I'm very happy as I found new 48mm valves for $23 each. Not modified chevy valves. I also sourced springs for $72. I will do some minimal porting and blending as recommended by a guy who builds these heads for all the local racers.
Any recommendations on what to do other than the standard work?
1 Post
Yeah, the guy built all of Chris Cervelli's heads. I trust what he says. I also have one of his heads on my car now with those springs and over 140k miles. I think they have proved themselves.
well some call it standard stuff some don't ..
correct consistent seat widths 3 or more angle measure every stem height taper turn the guides don't back cut the exhaust valve CC the chambers after doing a little relieving around the valves .
Cafulley do spring install heights and check pressures at full lift as well
match port the inlet manifold and perhaps your Phenolic spacers
if the port job is big CC the ports also
1 Post
Also as a bonus the NA head has a larger volume exhaust port. My brain trust that I was going to have build it says that because of the larger port it requires minimal porting, more of just a clean up.
I'm thinking of sending the head to swain tech to have the chambers and exhaust ports coated to help keep heat out of the coolant.
I haven't heard of anyone removing the ceramic liners - I don't think it is possible as I remember a graphic somewhere showing how the heads were cast with the ceramic ports already in the place and they are sizeable.
