Arrrgh - engine re-assembly issues - need help
Old 11-26-2009, 03:00 PM
Josh B
Josh B's Avatar
Default Arrrgh - engine re-assembly issues - need help
Ok - got my head back from the machine shop with all of the intake valves replaced. I bolted it back onto the block and before attaching the cam tower or intake did a leak down test. I am getting 80% leakage on all four cylinders and it is all coming out of the crank case! Cylinder walls look fine - what could I be doing wrong? I guess the head could be warped although I don't think I over heated. I didn't get it surfaced because it is o-ringed. Other than that I am at a loss....
Old 11-26-2009, 03:04 PM
theedge
theedge's Avatar
The engine needs to be warmed up for an effective leak down test.
You could put a bit of oil in the cylinders if youre wanting to leakdown test the cylinder head... That should help.
Old 11-26-2009, 03:30 PM
Tom M'Guinn
Tom M'Guinn's Avatar
How was it running before you pulled the head? Burning any oil out the exhaust? Are you sure you are using/reading the tester correctly? Are you sure it's not 80% not leaking? That would be tolerable on a cold motor. Piston under test should be a tdc -- rotate the engine to locate the piston, so that the rings seat normally. If its coming out the crankcase, that would point to rings, but I'd think you would have known if they were that bad before pulling it apart. You can still check for flatness of the deck and head with a precision straight edge, you just need to work around the o-rings. Sorry it's not cooperating. Good luck.
Old 11-26-2009, 06:20 PM
Josh B
Josh B's Avatar
I know it isn't the gauge as this is the same one that I got great leak down numbers on the same motor about 6 months ago.
For the heck of it I bolted this head onto a spare short block I have in the garage and got much better readings. I really don't know what to think at this point.
Old 11-26-2009, 06:22 PM
Josh B
Josh B's Avatar
Hmm - maybe I should just bolt on the cam and intake and see if she will start?
Old 11-26-2009, 06:26 PM
brad-cam
brad-cam's Avatar
I rebuilt a spare motor using a good block, new rings and did a leakdown test on the engine stand and also got some pretty poor numbers, a little like yours. I've chocked it up to rings not seated and a cold engine
so will just wait until I put it in the car and break it in. I would recommend that you put it all back together and start it up and do the tests on a warm engine.
And yes, I still have the spare motor. The one I rebuilt that is in the car is still running strong!
Old 11-26-2009, 06:42 PM
CarbonRevo
CarbonRevo's Avatar
Josh- Not to be off topic as I'm sorry for your troubles, but what engine harness is that? I love how clean they look. Is this Lindsey racing harness pieces?
Old 11-26-2009, 07:20 PM
Josh B
Josh B's Avatar
It is the Lindsey racing stuff but I made a bigger project out of it than needed I completely disassembled my old harness - removed anything I wasn't using like the diagnostic plug and top dead center sensor, and then put it all back together through the original firewall rubber hose. It took about 2 months working on it on and off.
Old 11-26-2009, 07:31 PM
m73m95
m73m95's Avatar
You have a lot of new parts that aren't broken in, to be doing a leak down test.
The engine needs to be warm (as said above), and ideally, each cylinder should be at TDC.
As long as you assembled everything correctly, you're worrying over nothing.
Run it, drive it for a few thousand miles, THEN do a leak down test.
Old 11-26-2009, 08:16 PM
CarbonRevo
CarbonRevo's Avatar
Damn...I really want to replace the majority of mine. Update the engine bay some to compliment my headlight delete and oil cooled turbo. Looks very clean though.
Old 11-26-2009, 11:33 PM
ilikemy944
Going with the pack
is quite monotonous.
ilikemy944's Avatar
Guys - I think we might be thinking too hard.
There isn't that much new stuff - this short block didn't get touched, rings/pistons/etc are the same as they were before.
The car wouldn't start and we were getting spark and fuel so we did a compression test and got 50psi.
Then 80-85% leakdown.
Only 'new' engine parts are in the head.
Old 11-26-2009, 11:36 PM
ilikemy944
Going with the pack
ilikemy944's Avatar
BTW - the 50 psi compression test bumped to 52 psi after adding some oil.
80-85% leakdown was with oil in the cylinders as well.
Old 11-27-2009, 12:54 AM
95ONE
95ONE's Avatar
Hoping not to insult, but no way around it.. You're sure you're using the tool correctly?
Old 11-27-2009, 08:39 AM
Van
Van's Avatar
If you have a nice straight edge, you can check the flatness of both the head and the engine deck. Use a piece of package cellophane (like from a cigarette pack) to slide under your straight edge.
Out of curiosity, how much do your o-rings "stick out" (proud above the surface)?
Old 11-27-2009, 01:06 PM
ilikemy944
Going with the pack
ilikemy944's Avatar
Yes - been used to test several motors prior.
Quick Reply: Arrrgh - engine re-assembly issues - need help
