WTB: Big Blacks or Big Reds (BOUGHT)
#31
I actually ordered mine from a yard in CA (listed on car-part.com). Hubs and spindles from a '94 968 for $150 as well (plus shipping).
#33
odurandina,
I appreciate your concern, but I have done some research on hydroboost and also talked with guys that have done manual brakes on these cars. Manual brakes supposedly work very well if you go with the big reds/blacks and 5/33 proportioning valve. You can also move the brake pedal linkage up a little bit to give more leverage. I am going to start with that and see how it feels. If I don't like it, I will either add hydroboost or go to a dual master cylinder setup.
Olli and Pete have gone up to the 6 piston GT3 front calipers with stock m/c and never complained about excessive pedal travel so in the end I can't make my mind up about all this. Not sure how much a tilton type setup costs but I would consider this if I were building another car with track focus.
#34
Will do.
Patrick,
Yeah, I'm curious how long the pedal travel will be. Guess I won't know until I try it. Maybe I'll post on one of the hybrid boards to see if there is someone local to me who has the manual setup with big reds.
ps, sorry to see your car as it is. Build another one! There had to be at least a few things that you thought, "I wish I had done it this way..." right?
Patrick,
#35
There was someone on here quite recently who I think was also doing a V8 conversion and he came up
with some bracket system for a dual m/c setup from memory. Looked a neat setup.
Well my first priority would be to put in a proper weld in cage and go from there.
#36
#38
Good setup. I've had the same with good results. I don't think you need the drilled rotors unless you spend a lot of time at the track, plus they crack pretty badly.
Wonder what Dan is moving up to???
Yep that was the bracket thingy I was thinking about. Interesting to read that they say that the pedal pressure for using a Tilton setup vs stock m/c is greatly reduced....
#39
I think he's going back to stock brakes for his racing class (due to rules change I guess). That would drive me crazy to have to do that, but it worked out well for me!
