MALE 6-pin Bosch connector to replace AFM??
Old 10-26-2009 | 08:32 PM
ramius665's Avatar
ramius665
Default MALE 6-pin Bosch connector to replace AFM??
Now that I've gotten far enough along in my engine rebuild, need to look at integrating my new Vitesse MAF into the stock harness. After all of the pain I went through to source a new DME harness, I'm not going to cut it up any time soon. As such, I need to source a MALE Bosch connector to to integrate into my harness from the Vitesse MAF. I have found a ton of websites that sell the female end, but no luck on the male end. Help!!
Old 10-26-2009 | 11:12 PM
JohnKoaWood's Avatar
JohnKoaWood
Marko at MKS MIGHT be able to come up with what you need..
http://www.mksautobusiness.fi/page_e...onnectors.html
marko@mksautobusiness.fi
You need part number 1928402464 off Bosch drawing A928000020 (if you use search on their site search for P/N 1928402452 ... 464 returns as not found...)
http://www.bosch-connectors.com/bogs...Token=55453655
I believe the part number you need is NLA, drawing was last updated in 2004, and a search returns no results for the P/N..may be a special order part from Bosch (subject to minimum order threshold of usually 3000 pieces...)
OR
You could do what another MAF vendor has done, and scavenge the connector off your existing AFM...
Old 10-26-2009 | 11:46 PM
theedge's Avatar
theedge
Male connectors with more pins than 2 or 3 are not really available.
Old 10-27-2009 | 12:05 AM
JohnKoaWood
Marko stocks 2, 3, and 4, pin males.... I can't find 5, 6, or 7... hmmm maybe I need to call a friend...
Old 10-27-2009 | 12:13 AM
Tom M'Guinn's Avatar
Tom M'Guinn
I thought I heard John has an adapter available these days, but don't quote me on that. If not, buy and old/dead AFM and cut the connector out. That's what I did -- put it in a little project box with VR harness going in one side and factory harness plugging into the other side with the connector.
Old 10-27-2009 | 12:15 AM
ramius665's Avatar
ramius665
Gotta go check the AFM and make sure the connector isn't burnt to a crisp, but it looks like that's my option at this point. John told me when I ordered my parts from him that he makes an adapter, but at $125 I just can't afford that right now. Still have $1153.47 worth of parts and about $750.00 worth of powdercoating and machining to pay for...
Old 10-27-2009 | 12:21 AM
JohnKoaWood
Rule 1 of 944 club is you never add up receipts!
Rule 2 of 944 club is you never add up receipts!
Rule 3 of 944 club is ... you get the point!
Old 10-27-2009 | 12:34 AM
ramius665's Avatar
ramius665
It's not about adding up receipts, but a quick guess is that I'm in about $8500 for this engine rebuild thus far. Right now it's about budgeting to get what I need *now* to get to the next step. All of the powdercoated parts are wrapped with bubble wrap and saran wrap until they are needed, to keep any dust/dirt/dog hair out of them. I HAVE to get this car back on the road before about January because we're buying a house. Don't want to move 15 boxes of miscellaneous parts/brackets/bolts and then start putting things together again.
Old 10-27-2009 | 12:38 AM
JohnKoaWood
Maybe we need to have a wrenching party at your house... I'll bring all my assorted toys along! (Power Bleeder, Torque Wrenches, cheese head adapters.. just to name a few...)
I'll be ordering new clutch hydraulic parts tomorrow, and my 951 will be back on the road... then I need to get to fixing my N/A...
Old 10-27-2009 | 01:45 AM
choinga's Avatar
choinga
John does have an adapter, I bought it when doing mine...but he doesn't sell it on the cheap, that's for sure...
