Got some parts back from the powder coater this weekend =D
#31
http://reutterwerk.com/forums/showthread.php?t=10151
Search my log on for RL thread
-BB
#33
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i want to powdercoat my big blacks to YELLOW for fun's sake. Kind of tired of black. I am between Massachustts and Philadelphia area a lot. Any suggestions ?
Allan -- Massachusetts -- 968 N/A but, soon going supercharged.
#35
Hey Man
![](http://forums.rennlist.com/upload/pbrdust3_copy9.jpg)
#36
Steve- Are you running zimmerman cross drilled rotors? I have the setup waiting to go on the S2 but would like to see how the rotors look after quite a bit of heat and miles. I'm split on whether to paint the hub of the rotor or not. Or powdercoat it. I'm a bit of a perfectionist when it comes to my S2. Do you have any wheel off shots that wopuld better dictate how the paint and rotors have faired over time?
Thanks! and sorry for the slight OT.
#37
I've got Zimmerman rotors, and they LAST... No problems whatsoever after 3 years and 20k miles. Even survived an engine fire! In regards to painting them... DO IT. I didn't even think about it when I installed them, and the hats are rusted to hell. Looking back, for $5 in high-temp paint, they would still look factory new. In fact, after doing working my way through this engine rebuild, I will paint/powdercoat/re-zinc every part that I EVER take off the car from now on. If for no other reason than it keeps rust and corrosion at bay. And for a bit of time spent prepping and painting, it's completely worth the effort. Just wait until I get the engine back together, I'll post pics from before/after and you won't even recognize it's the same engine.
#38
Hey Man
![](http://forums.rennlist.com/upload/951pdsmall.jpg)
#39
Looks like I will paint the rotors then.
And I know all about painting things. Every single bracket and piece under my S2 hood is either painted with high temp aluminum color or high temp semi gloss black. I've hand sanded everything and painted it all. Even went to the trouble of painting the hard metal brake line bracket on the rear brake system. All brake shields, struts, shocks, brackets on underside even. I've also replaced almost every bolt under the hood with a stainless steel one. So I know the pain staking work it is. Well worth it though!
#40
Cory, I'm a little jealous. And here I thought that my wife and I were getting obsessed with sanding/painting/finishing everything! But every time I think we're almost over the edge, I look at the fire-charred pics from 6 months ago and get my second (or third, or fourth) wind.
