Yet another offset question
It seems like 18x10 ET55-60's would sit perfectly on the back of a late offset car. My 18x10 ET65 on my S2 sit about 1 fingers width from my ebrake cable and spring plate bolt. I run 285/30/18's. I may add a 7mm spacer as the rears sit in a little further then I like. I easily have enough room for 295's and can say that with the right wheels, 305's would fit under stock body work and suspension settings. Maybe I should try this on my 951!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
It seems like 18x10 ET55-60's would sit perfectly on the back of a late offset car. My 18x10 ET65 on my S2 sit about 1 fingers width from my ebrake cable and spring plate bolt. I run 285/30/18's. I may add a 7mm spacer as the rears sit in a little further then I like. I easily have enough room for 295's and can say that with the right wheels, 305's would fit under stock body work and suspension settings. Maybe I should try this on my 951! ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
