NGK BPR6ES vs Bosch Super Copper Spark Plugs
#46
Except for the vast amount of empirical evidence stating that BPR7ES are perfectly fine for a normal DD 951.
The BPR7ES is even factory stock equipment for some cars, they are not a significantly cold plug.
I guess if all he does is cold-starts and .5miles trips to the corner store then maybe a 7es is too cold.
-Rogue
-Rogue
I agree, either would work fine, with the caveat, that a the heat range difference MAY foul more under certain service conditions...
#49
#52
#53
If my tunning was off, I would have blown my HG already these last 2 years since I had my head and exhaust manifold gaskets done. I have creeped up to 16 or 17psi in third at times, my plugs all burn evenly and they are the tanned greyish color they are supposed to be... and I drive 34 miles daily roundtrip to work, the Bosch Super Plus are great and they are better quality than the NGKs and it is visibly obvious, plus LR uses them and they are OEM...
#54
Small Business Partner
You tuning can be off and not blow a head gasket.
I'm curious on how you can determine that the Bosch is better quality then the NGK...
They work good for you, great. You choose to throw in a hotter plug, instead of fixing the cause... To each their own
#55
Hotter plug? Those are the plugs the application calls for, as is the BPR6ES, the equivalent.
#57
#59
I can add a data point on the plugs. In my car with a TEC3 my driveability is better with the Bosch WR5DC than it is with the NGK BPR7ES, and yes I have had the NGK miss in the engine with no tuning changes and when switching to the Bosch Super + WR5DC, the car runs better. I know the driveability thing is a completely subjective feeling, but it is there, at least in my car.
No dyno comparisons or anyway to quantify it, other than for me, the standard is now the Bosch versus the NGK in the past.
#60
