How much boost can a Widefire HG hold?
Basic Sponsor
damn, Luis if you keep asking questions like that I am going to ask for a permanent ban on you. Has nothing to do with the HG, and wide fire over stock has little or no benefits at all unless you have a o-ringed head. How much boost you can run is dependan of factors like , turbo, injectors, a/f mix , timming. Special tool ran 35psi with the stock head gasket.
I agree.
As said, it's not a HG problem if it blows, it's bad tuning. I have also ran over 35psi on my widefire I installed 6 or years ago. I has been abused, ran hard, on extended boost times and still holds. There was nothing originally wrong with my stock gasket but after my headwork I decided on a widefire since it was supposedly a little stronger.
I will say this, if anyone is having problems with headgaskets DO NOT install a MLS. You will regret it when your pistons see sunlight out the side of the block.
Small Business Partner
+1
-Rogue
Quit Smokin'
ahhh yes, one of my favorite questions.
Also in the top 5:
How much wood could a wood chuck chuck, if a wood chuck could chuck wood?
Seriously, I think the number of positive posts would have been greater had you simply made a thread stating only, "I don't get it".
Try the search function. Head gasket problems are plentiful.
Also in the top 5:
