Interest in DIY chip tuning?
Small Business Partner
Is there an interest in the 944/951 land for DIY chip tuning?
Anyone interested if I make a walk-through?
Opinions on what is important, or needed?
Other opinions or constructive criticisms?
-Rogue
-Rogue
Yes. The basics - the three timing and fuel maps, RPM limit and FQS scaling:
Will also include the AIT table, and Baro constant. These will be useful for those wanting to convert to MAF, as both compensations will need to be flattened.
I used a freeware program called TunerPro. Very commonly used for DIY tuning applications.
I simply wrote the definition file, which allows us to use it with the DME.
-Rogue
-Rogue
You can burn chips, using a burner..
Or use an emulator, the Ostrich to load changes instantly and is re-writable.
Ostrich 2.0
-Rogue
Ostrich 2.0
-Rogue
This is already done in the definition file that I've made.
-Rogue
