FS manual sunroof latches $55 shipped
Rainman
Pair of manual sunroof latches for any year 944. These are a very easy swap to convert to a dependable sunroof in a few minutes. You simply unscrew the power latch receivers on the sunroof, put these in their place, and remove the cover for the latch sliders. Never again will you have sunroof clutch adjustments or failures or stripped gears, opening the sunroof takes less than ten seconds.
These are used and have wear lines of where the latch spun around but they are fully functional.
Looking for $55 shipped
Rainman
yes. the latches are the actual supports for the sunroof. they unlatch, turn around, and then they sit in the rain gutter in the roof and hold it up. from the factory there was a leather strap to hold the roof down but ive never had any issues with driving at high speed, roof open, strap unbuttoned (although i do have one installed).
fluidplay for $55 total ill drive them to you lol
