Anyone have lifters FS
How much is a used set going for nowadays.
Just checked out the lifters and of the 8, there are 5 different styles of "INA" stamped on em. What were the original ones stamped? Are these the infamous ****ty ones that go bad?
FWIW, all 8 seem to be very hard (cannot compress) with the button fairly low. I'll pressurize em and see if that helps later on tonight. off to school now..
Found this for you, I knew I would find it if I searched long enough...
http://benms.com/944lifter.html
I also have 2 copies of the FSM that I religously use when doing work... you would be amazed at the number of questions posted that can be found by looking...
AND I remember 95% of what I read, not photographic, but close... Makes me good at what I do...
If I find good info (spec for compression of the hydraulic lifters in this case) I file it, and keep it for future refference...
How Bout this one?
http://www.alanara.fi/Possu/ENosat.html
and I can find it even when I am on a different comp (like at work right now...)
(I have a bunch of old lifters if that's what you are looking for...)
