Water-in-oil diagnostic help??
Here's the back story.
- Stock TurboS engine that has been rock solid for the last five seasons.
- The only problem over this perod was a head gasket failure [water jacket across to #4]
- Head gasket popped again at the end of last season.
- There was no massive overheating after the gasket failed - I shut it down as soon as the dread white smoke appeared.
So, finally got around to replacing the head gasket for the VIR race in June. After getting everything finished, the engine started and ran nicely. While coming up to temp, I noticed water in the oil and shut her down.
After cursing myself for hurrying the head gasket work [and missing the race] I sucked it up and replaced the head gasket again. Very carefully this time. Started it up, and guess what? Water in the oil again!!!
So, where's it coming from?
- the head gasket? Doubtful, given this was the second replacement.
- the internal oil cooler/filter console seals/gaskets?
- the turbo?
- a cracked cylinder head?
- a cracked block?
The coolant system holds pressure when cold. Set it up at 17psi, and after 12 hours it had only dropped 2psi.
Two big questions that I'm struggling with now:
- Is there any way to isolate which of these possible sources is actually leaking?
- Is there any other leak source I'm missing?
I guess I'm paying for the many years of solid performance from this engine. Its truly kicking my a$$ at this point.
- the turbo?
- a cracked block?
Warped head is the only item I can think of to add to your list.
Only other questions is did you get all of the water out of the oil last time around. How are your hoses mounted to your auxillary cooler, can they form a trap so that the fluid in the aux. cooler doesn't/cannot drain when you pull the drain plug?
Oil filter housing. Pretty common and if it hasn't been done yet then it's due.
The struggle here is to try to prove where the leak is, rather than trial and error, if that's even possible.
UPDATE:
The coolant system has been pressurized at 17psi for 48 hours, with no drop in pressure.
Does this confirm that there are no currently active water to oil leaks?
I'm hoping that there is still some residual water in the oil circuit that needs to be found and cleared out. I guess its possbile that the water-oil leak is only active when the engine is running?
I had a very similar issue and mine held pressure fine, mine ended up being the oil cooler seal. I would look at that. Are you getting milkshake in your breather or can you actually see water in your oil??? I was only getting milkshake and once that started the car was shut down and towed to the shop.
The pan is empty at present. I was hoping to see water working its way into the oil circuit, and maybe some clues about where it was leaking. No luck with that.
I'm going to open and drain the two extenal coolers and their lines. If it turns out there's a lot of water there, maybe another run with fresh oil just in case that residual water was the source.
The oil console is the likely suspect, so that looks like the next step.
FWIW, in the last run the oil was clear on the dipstick but there were water droplets in the drained oil.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
How did you find the water in the oil?
If the answer is 'when I drained it' I will bet that you had coolant in the oil cooler lines from the last failure and once you warmed it up it got back to the pan.
Cleaning the oil cooler after a failure is a must...and a pain.
it might be a hole somewhere that 17 psi cant leak through, but 60-75psi that the oil sees could
