Knock counting with Backlight and reset! DIY added in post #37
I'm modifying the third one I bought right now (1st unmodified is in the car, 2nd is modified sitting on my table, 3rd is still sitting in it's box), and plan to post a DIY, and offer a cost plus core, or just cost for me to do the modification...
As soon as I finish the DIY I'll post it, along with anything else I come up with...
Also keep an eye over there, as I know it won't be long before I get my hand slapped for trying to do a favor...
I'll get it done this weekend, and post a DIY with DIFY (do it for you) pricing...
Sorry, life has once again gotten in the way for me, but I will re-focus this weekend.. I have 1 modded that I still need to install, and 1 un modded in the box that I will do a write up with..
SORRY... please don't get mad at me...
Drive-by provocation guy
Would you only be offering the mod or buildnig them from scratch and selling?
Also, what is an accatable knock count?
John, can I hijack your thread a little bit? I've been logging my knock via my Traqmate - so I can see where and when it happens on the track. I can say that pretty consistently I get one or two knock impulses once I'm full throttle exiting a turn (I log throttle position, too).
Think this is anything to be concerned about? I assume, because the knocks are pretty singular, that the computer is backing the timing off to reduce it... I suppose I could play with my octane and/or LBE and see if the knock counts change.
Van, try playing with your FQS, go no fuel change, -3 ignition, I bet your knocks dissapear... but so will throttle response and top end...
I got 23 knock events on my tri home today...some spirited pulls on teh highway, usualy get 1-2 knocks on WOT shifts for a few reasons... mainly because I have advance my timing maps..and they still need refined to eliminate the knocks...
if your AFR s are good, and you have instrumented throttle position, air flow meter / MAF voltage and knocking you should be able to target ignition map modification (X RPM at Y Load.. retard timing untill you stop seeing the knocks...)
BUT
Your knocks may not be actual knocks unless you are seeing them at WOT... at part throttle there is little boost, and little tendancy to knock... you might just need to back down your WOT map at X RPM, when modifying my ignition maps I usually go in .1 degree increments... I advance untill I see knock, then I retard to loose the knock, then I go another .5 degree retard to avoid knock if I should get crappy fuel or have a problem with elevated IAT...
If you aren't tuning your DME..you should be able to rid yourself of the knock using the FQS to retard timing -3... see if it helps while being aware it WILL impact throttle response and top power...
Tod,
In a perfect world, zero would be good, Knock is bad for your engine, the environment, and over all performance...
That having been said...
Knock is caused by many different factors, to the extent that Porsche put the KLR in for just this function... at elevated manifold pressures, when HOT intake temps are encountered, all it takes is a bad ignition signal, or some contaminated fuel to destroy your engine... 1 Knock CAN kill your engine if it is bad enough, or timed at the "right" time...
Timing control is how Porsche chose to control Knock, when the KLR detects Knock, it retards the ignition.. This is OK... a few knocks here and there, at WOT especially at higher RPMs SHOULD be OK, but generally knocking should be avoided...
The Knock counter is a tuning tool.. it will tell you when you are pre-detonating fuel, I am using it to let me know if and when I am running my ignition too advanced, have gotten bad fuel, have IAT too high to be good, or if I need to get off boost...
Zero Knocks would be good, an could be done by not boosting, or running ignition retarded, or both... BUT that wouldn't be much fun would it?
I have asked permision to offer service for cost... and trust me, Not only will cost be reasonable, but varied in structure... (Modified, Modified with core, send your to be modified, or a kit to modify your own), all will most likely be very cost effective... If I am allowed, I will post it in the DIY writeup.. If not allowed I will post the DIY and find some other way to offer it outside RL, and not to be spoken off in RL... Like my SIG?
BUT
Tod,
BUT
BUT
Here's a screen shot of my data.
Each color is a different lap. The top graph is RPMs, the middle graph is the knock signal (from the KLR) and the bottom chart is the TPS.
You can see, this all takes place at turn 10 at Watkins Glen.
Anyhow, the blue lap had 3 spikes at WOT - red and green both had one count at WOT.
The datalogger is 20 Hz. And the blue counts happens in less than 1/2 a second.
My inclination is to not be too worried. Maybe some day I can log boost pressure, too.
(sorry for the large image size)
Van,
What AFR are you seeing at those times??
3 counts per gear doesn't seem to cause any damage that I have seen.
You may try to add a bit of fuel through the FQS. There are 2 different settings above stock +3 and + 6. You can also pull a little fuel and timing via other positions.
My thought is that you may make just a little more power using the +3 or 6 setting and eliminate the counts.
Van,
I'll have to play around with those +3 and +6 settings some time. Unfortunately, I don't think I'll have this car back to the track until next spring.
RE low RPM knock counting, I believe you can add a simple pressure switch that would only enable the knock counter on boost. This should eliminate off boost knock. Can't recall the name of the switch type off hand but they were pretty cheap. I think the 5lb one was about right.
You probably could log the stock O2 sensor yes, but that wouldnt really tell you much. They give you a small window around 14.7 and thats it.
ALL of your logged knocks are at 5400 RPM, WOT, within .5 seconds of throttle application... too bad you can't modify the timing map at WOT...I would pull some timing at 5000 RPM from the WOT table, and I bet you knocks go away...
What is your LBE set to? I'm betting 15 - 16 PSI..and you are running pump gas?
You have a few options... FQS is a 6 position switch on the DME, doesn't affect altitude compensation, it affects fuel and timing maps, but is affects the entire table, you are only having knock at 5400 RPM... all 3 laps show knock at the same RPM... I would switch to position 4 or 5... I'm betting you are at position 1... if you pull your DME, you should find a small black cap on one side... it might not be there... insert a small (3mm I believe) alen wrench and carefully turn clockwise...you should feel it click... but be aware you will be pulling 3% timing from the entire range of throttle positions and RPM..so she MIGHT feel sluggish...
Your knocks aren't that bad, but the fact that they all happen at the same RPM is of some small concern... can you run custom chips in your class, or do they pull the DME chips to verify stock setup? IF you can modify the chips, I would run your chip image, with -.2 at 5000RPM on the WOT ignition table... but that is only if you can run chips... or you could lower your LBE a little to see if it eliminates the knocks...
Connect pin 1 to the 2nd solder pad away from pin 4... momentary push button from radio shack will reset when pushed, I added a 220 ohm resistor to act as a current limiter...
I have almost finished taking pictures, and should be able to finish the DIY tomorrow, Sunday at the latest. while you have it apart add a 12V bulb on wires between pins 1 and 2, glue the mini bulb / led to the side of the screen (in the opening to the right side) and you will have back-light when powered on... I have managed to fit it all back together using a 2mm LED and micro switch, I now have brighter micro bulbs I am using in the write up..
