This close to giving up
before you do anything drastic, stick another pressure sender in just to double check your gauge - use a sandwich plate under the oil filter & you can keep the stock sender as well.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I still haven't seen the answer to the question about the hot oil pressure - what is it? You just said it 'drops off'....to what? If the answer is zero and you don't here a lot of lifter clatter then its a gauge issue.
After rising to near 4bar when on the throttle, the oil pressure drops a little below 3bar. At idle, it falls below 1bar. This is when hot.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
1 bar hot (15psi) is still within factory tollerances - and it not uncommon in hot weather!
Factory limit is 1 bar per 1000 rpm.
Hmm. That's good news for my idle. However, what is your take on the declining oil pressure under throttle? You are making me feel better about my situation.
1 bar at 1000rpm is still not enough, In my professional opinion. i can understand that if this is heavy city driving then you will the oil very hot(super heavy start stop traffic, on the track you would ruin your crank in one session. if you wish to fix your problem get a 20w 50 oil.
whaen you say "hot" what sort of driving are you doing? where is it happening. i really do not understand why people keep trying to go thin oils in these cars. look at the owners manual ofr the 951.
-10celcius to 40+celsius it stated 20w50. its virtually the cheapest oil you can buy.
Going with the pack
is quite monotonous.
ummm...
Having seen this very thing happen with my own two eyeballs in a 951 with a stuck thermostat I would like to say "ummm... thanks."
Going with the pack
Here's a thread for reference, with this quote:
https://rennlist.com/forums/944-turb...re-issues.html
I'm not saying this IS the problem. It is something to double check.
So thank you JoKA, for "ummm..."-ing.
Cliff notes are that on my 87 944 turbo with 139k I'll have good oil pressure on startup and then after the car warms up at higher RPMS oil pressure will decrease. Normally my guage will show 2.5 bar or better at warm idle. Now after warm up and higher rpm driving she will show 2 bar at idle and maybe only 3 bar at running at 4k rpms. These numbers don't sound that bad but I've observed under acceleration the pressure going down - there has to be something wrong.
Last edited by ilikemy944; 07-28-2009 at 10:12 PM. Reason: Made it a little nicer. :)
The thermostat was not replaced. However, I misheard my mechanic earlier. There was metal near the oil drain plug. This is systematic of rod bearing failure, correct? I suppose at my mileage that I was due for a rebuild. I suppose that I'll keep it and see if I can scrape up some cash to do a full rebuild in the Winter. Thanks everyone for your help.
