EZ Pass - Hate the look? Solution found!
New solution to eliminate the look of that unattractive white square on your windshield. EzShadow and new black attachment strips make the EZ Pass virtually
invisible without impacting the EZ Pass use.
Not having the EZ Pass affixed creates safety issues at the toll plaza and the possibility of fines. You can paint it black but it's messy and still leaves the
attachment strips quite visible. EzShadow is the simple and inexpensive solution.
Check it out at www.ezshadow.com. See the difference it makes in the comparison below.
I had mine in a bag in the rear hatch area and it still went off so I think they don't have to be right up on the windscreen. Don't they just send you something in the mail if it doesn't go off anyway and then you just give them your number and they take the money out?
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Here in NorCal, if you just remove the device, they just charge your account using your license plate number. (But I've heard that they are trying to reduce that sort of behavior because it's more costly to them).
