WOT, lose spark @ 4.5k rpms
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
I do not think it's your plugs and the plugs you are using need less volts to creat the needed spark then the older style plugs so if you switch to the other plugs I will probably get worst.
they are at the rear of the engine on the top of the bellhousing.
My recommendation though is... before f'n with them, exhaust all the other ignition first
Also let me add that it only seems to do this in 4th. 1st, 2nd, and 3rd doesnt seem to be affected. I'll have to take her out later and run another simulation to be sure though. Thought that might be a helpful piece of the puzzle.
they are the trigger for the computer to send the correct signal for spark timing among a couple other things
I would change plugs and gap to ~ .028 and see what it does
Thanks for breaking it down for me Blown, I sort of assumed thats what it was for but if I was wrong who knows what type of trouble I'd get into.... ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I'll follow the advise of you and the others who have offered their thoughts.
I greatly appreciate everyones input....I want to make sure I sort this our before my VR S3 shows up.
You didn't describe the cutout...but if it's a soft cut...ie...cough and sputter...one more item to look at (and John mentioned this) is the coil.
My car would run fine at no boost and low boost but as you combined upper RPMs and higher boosts the car would stumble and cough. Bad coil.
